A/C fixed now...
Got it all straightened out and everything seems to be where it should be low side 35 high 215 psi. Good to go thanks for all that chimmed in!!!!!! Road trip will be much more enjoyable. Thank You
How many cans of 134 should the system take?? I have three 12 oz cans in there right now. And its only blowing 50 degress? I do have the low pressure side hooked to the port on the dryer and high is hooked to the port on the drivers side next to battery.
The US general gauges are showing low side 46psi on the very inner circle, but if I read the very outter where it says R134A it reads 10?
The high pressure side is showing 55psi inner and 15 outter??
When I just the truck off I heard kind of hissing sound coming from the blower motor area, but quickly went away and the pressure in the system is holding steady, not leaking and valves were closed.
With the truck off the low side shows 90 psi inner and 27 outter, high side shows 100 psi innner and 30 outter? See pics below first is the truck running and second is truck off.
Please help trying to get this done before the road trip in the am!!!!
