Hey guys Ill try to make a long story short. I was driving home from the parts store the other night(getting parts for the bike) and the motor died(1 block from the house
) I had enough momentum to carry me off to a side street. Once I came to a stop I tried to start the truck and when I cranked it over it cranked really slow. I knew it was not going to light but I still tried in vein hopping, just maybe it would.......nope, didn't happen, batteries died. Tried cranking it for about 4-5 sec 2-3 times then they dead. Got the truck home(Dad towed) and I have had the batteries tested and the alternator tested and they all tested good(made them test everything 2 time) I cleaned the negative to motor connections(grounds) and put in a new starter solenoid and glow plug solenoid.
But heres the crazy part...
I have 12.57 volts to the starter when the ignition is in the ACC/RUN position, when the key is turned to the ON position it goes to.07 volts. What is with this?
:***: And I cant seem to jump the started solenoid, like the batteries are dead(less than 1 year old), but they tested good(at the parts store) and I charged them on a 750ma charger for 20 hours(like recommended). And this all happened while I was driving and I dont know what eles to try. Is there a short, is it a bad ground, or am I just missing someone, but I have been trying fix this for3 days and need help!!!!! thanks guys
J
) I had enough momentum to carry me off to a side street. Once I came to a stop I tried to start the truck and when I cranked it over it cranked really slow. I knew it was not going to light but I still tried in vein hopping, just maybe it would.......nope, didn't happen, batteries died. Tried cranking it for about 4-5 sec 2-3 times then they dead. Got the truck home(Dad towed) and I have had the batteries tested and the alternator tested and they all tested good(made them test everything 2 time) I cleaned the negative to motor connections(grounds) and put in a new starter solenoid and glow plug solenoid.But heres the crazy part...
:***: And I cant seem to jump the started solenoid, like the batteries are dead(less than 1 year old), but they tested good(at the parts store) and I charged them on a 750ma charger for 20 hours(like recommended). And this all happened while I was driving and I dont know what eles to try. Is there a short, is it a bad ground, or am I just missing someone, but I have been trying fix this for3 days and need help!!!!! thanks guysJ
