HELP truck died in middle of the road
Matrix37495
The Amish Wolfman
Terre Haute, IN
The regulator just needs that key on power to know when to 'turn on'. Think of it as a signal wire, not a pass through destination...
91idi
Fiberglass *****
X
Yelp. I found a bolt on the cab under the hood. Put an eyelet on the wire then ran it over to the battery
pwjackson
Saint Paris/OH
Truck is fixed!!!! The grey plug with the green and yellow wires was the culprit. I took the plug apart to check for corrosion and it was melted a little inside and corroded. Picked up some fully insulated spade terminals to make new connections. Truck runs and starts fine now, I was not able to find anything else wrong.
Thanks for all the tips and pointers!!!
