nitroguy
I need your help guys. Smokey Pete is blowing serious smoke. I fear the worst, but figure I'll check here first. Video below shows startup, then after high idle/advance kicks off (respectively).
Here's what I know:
-Lost my lower radiator hose on my drive into work Thursday. Got there and coolant everywhere. Not sure why it blew off, I've driven it about 400 miles since the rebuild, and much harder than I did on this trip.
-Drove to Napa, got two gallons of coolant.
-On my way home, temp spiked the gauge to the far right. I was going about 30mph, I pulled off right away and opened the hood.
-Poured in two gallons of coolant, and three gallons of water (it's what was available).
Drove it home. Temp spiked once more, three miles down the road, I pulled off, but this time temp swung back down and drove normally back home at 55mph. I assume this was an air bubble?
Then at home, trying to diagnose, I put a new CDD injection pump and injectors into it. The one I had was an NA pump, so I turned it up 2 flats (freshly rebuilt banks turbo).
Seems like it idles a ton smoother than it did before, but, uh, the smoke. So much smoke. I can't tell if it's sweet or acrid.
I haven't seen any coolant in the oil, or oil in the coolant.
Coolant keeps burping air, no matter how many times I bleed it at heater core or radiator cap, there is ALWAYS air in the system.
Last piece of (maybe) relevant info, my upper radiator hose gets rock hard until I bleed air out, then it gets completely empty. Then rock hard, then empty out, on and on.
Anyone have any ideas? I'm at a loss on this one.
Here's what I know:
