Help -- Parts Info Fuel Filler "Box"
6T9burner
SVAZ
Hello everyone. So, I'm fixing the fuel filler neck, did the air return line mod, and a few other things. Here's my issue, the box that the fuel filler neck attaches to is jacked. I have searched as many terms as I can to find a replacement. Does anyone know if something off a newer vehicle, that parts are still available for, will work? I have attached pictures
1986 F250 6.9L Diesel
The stock picture is from a 79 Bronco. The others are from my piece of crap.
I'm no expert but I suspect any truck gas or diesel in a wrecking yard from probably 1986 up to say 1996 will be a direct fit...
chillman88
Central NY
I did a little looking and only found one place that listed it but it said "out of stock"
It was listed as the filler neck "housing" for what it's worth. As was said, I'd imagine it would likely interchange from 80-96 F-Series so a GOOD dealer might be able to locate one for a 96?
There are universal aftermarket ones that could be made to work if you end up desperate.
6T9burner
SVAZ
I finally have this issue repaired. I found a fuller filler neck housing out of a 79 bronco. With a few minor modifications, this thing fits great and is much stiffer than the original.
happy to hear you fixed it. Nothing worse than trouble during a fill up.
Vinceslamer
