Well I got the bar thingy installed and I have to say it works great! I had to stack a couple of washers under it to give the lock nuts room to turn, and the 8mm bolt in the alternator doesn't fill up the hole in the heim joint end completely (I don't think this will hurt anything). Adjusting the belt tension is super easy and accurate. I'd recommend doing this to anyone especially if you are running a 3g alternator with v-belts and need to keep the belt tight.
