Help IDing a turbo.
rjjp
Needs to go test
Clare, Mi
I acquired this turbo last summer, and I believed it to be for a 1st gen stroke, but the AR is 1.0 rather than 1.15. Can anyone here point me in the right direction on this?
Sticker on the compressor housing
Exhaust AR
Compressor AR
Diesel_brad
Dunce
gilbert pa
I am with Calvin. That blue /green is a dead giveaway. Fords PSD turbos are bare aluminum and cast steel And that bracket on the intake side is diffinaly not on a PSD pickup turbo
Black dawg
sw mt
I guess I didnt see that was the exhaust housing, and I agree on non ford.
94f450sd
somewhere,ma
then you havent seen a 99-up turbo.the bracket is for the wastegate actuator on 99-03 SDs.
international and ford use the same same turbos except on the school bus motors.
rjjp
Needs to go test
Clare, Mi
Any chance the .82 AR wastegated powerstroke exhaust housing would fit this turbo? It looks like they are the same, and I know where I can get one, I have access to two wastegated powerstroke turbos for parts, one with wasted bearings, the other ate something and screwed the impeller.
94f450sd
somewhere,ma
it should fit.only difference i know of is the ford runs the ebpv and a waste gate and IH doesnt.
