Help Identify this Rear Axle
cre1992
Florida
So I want to change the diff fluid the rear diff of my truck, I was thinking of changing the diff cover with an aftermarket cover as well. My truck is 1990 F350 4x4 Chassis cab dually and the axle code is a W5 which I believe comes back to a 4.10 10.25 LS. I haven’t counted the bolts on the diff cover yet.
I see that many 10.25 diff covers are for srw applications only. Can anyone shed some light onto this? Here’s a pic.
gnathv
Athens, Al
This is the stock cover I had on my f250 and f350 dually.
I don't think that there would be a difference between the diff covers for a single wheel and a dual wheel. I could be wrong, but that doesn't make any sense to me if they are.
chillman88
Central NY
I don't believe there is a difference. I've never seen anything to indicate there was and I have one of each.
fordw60s
TX
Depending on what kind of cover you are looking for you may want to check out this series that Gale Banks did on diff cover research. This is the first in the series of videos on what they looked at and it is pretty impressive to see what the fluid dynamics happens in the diff.
cre1992
Florida
Yeah I watched that series a couple of weeks ago. Interesting for sure. But not interesting enough for me to fork out $400 :rolleyes: , especially on a truck that isn't a daily driver!
The other thing is that it has a lifetime warranty even if you break off the cooling ears. I have other things I could spend the $400 on lol.
I also want to know where are the rest of the results for the other diff covers they tested. I believe I saw an AFE and BD in the video, but they didn't mention it later on in their analysis...
cre1992
Florida
There is not a difference, they use the same cover.
That is what I thought. However when you look at many of the aftermarket 10.25 diff covers, they say for SRW applications only. Thus my curiosity.
cre1992
Florida
On Mag Hytecs site:
Overall height 3 7/8″
2X4 & 4X4 F-250, F350, – 1986 to 2016 including some 2017 with 12 Bolts on cover.
Single Rear Wheel
Includes: Bolt kit, Drain Plug and Dip Stick.
Capacity: 6 Quarts
BD Diesel 12-10.25 & 10.5 Differential Cover
1989+ 12-10.25"/10.5" Single Rear Wheel Ford F-250/350
Fitment Notes: BD Diesel 12-10.25 & 10.5 Differential Cover - 1989+ 12-10.25"/10.5" Single Rear Wheel Ford F-250/350 - 1061830
AFE 46-70022 12-10.25 & 10.50 DIFFERENTIAL COVER
Fits the Ford F-250/F-350/Excursion 10.25 & 10.50-12 Bolt Axles
Will NOT fit F-350 Dually models
The only reason I can think of, is that the early 2000s F350 duallys had Dana 80s. So being these covers fit a range of years, they are advertised as such.
u2slow
bilge rat
Coastal BC
Correct on the Dana 80 F350 usage for 99+. But it's not exclusive. A 5.4L gas f350 DRW can still have a 10.5".
BR3
Mt.juliet , TN
Any 10.25 or 10.50 cover is interchangeable. All the way up to current. But for that matter so are the internals mostly lol. Those covers (gnathv) were stock in the 08 era, but never on OBS. Just a good upgrade.
Correct again, most of the duallys 00+ got Dana 80's, that's why they don't work. All obs axles (non f-super duty) are 10.25
We had some lengthy discussion a while back about banks. I don't 100 percent agree with all the conclusions he draws, but a cool design either way.
geardaddy
st. paul mn
any 10.25 or 10.50 cover will work
