Did you check compression?
Most of my technical writing is done with TECH 101 as the very first portion of the title. Do advanced search then tech 101 for key words choose title and my username, you will find a selection of various articles that may help you with your truck.nm I found it. Now I just need to find a diesel compression tester
Oil itself won't cause it to over heat.
I think you have a pinhole somewhere. Only letting compression into the coolant jackets, not coolant into the cylinder.
