lastbugle
Hi
I am trying to do a compression test and I took out the glow plugs, but the part from the test kit that I think should fit that looks like a glow plug with the same thread but it wont screw into the hole like it hits a lip inside the motor. theres another little part in kit that fits and will screw in but its so small I cant hook up the tester the tester has a 90 degree angle to it and wont go on.
I got the tester from harbor freight if that helps?
can I test it another way besides the glow plugs? guessing maybe the injectors
at loss for ideas thanks for any and all help.
