Ya, what ever fuel was in the tanks at the time was used. i did the oil change and fuel filter change at the same time. When I replaced the fuel filter the local shop that sold me the injectors thru in a bottle of Stanedyne(?) fuel lubricant and suggested filling the filter with just the additive, so I did. They said it would help break free any stuck parts in the injector pump, since it had been sitting for some time.
During the same time as the oil/fuel filter change I did the injectors/glow plugs/return lines and fittings. A few of the return line fittings were leaking pretty bad after I replaced them and the fuel was collecting around and I assume leaking into the crankcase breather hole. So how much fuel might have gotten into the oil I am not sure, but some did and it could have thinned out the oil making it easier to get past the rings. So I need to replace the oil again. The oil I am using is Delo 15-40W.
How much oil, well it used about a quart on a 180 mile trip. How much oil should this engine take during an oil and filter change? I put in 10 1/2 qt.
As far as how long it had been sitting, I am not sure, but it did have grass and moss growing. It was driven from Eugene Or to Portland Or on that oil/fuel. The oil had some sludge in it, so I ran 1/2 qt of Marvel Mystery oil in the engine before I changed the oil.
I am not sure how many miles the injector pump had on it, i will look to see if I can find a rebuilt tag on it.
One thing I should mention is the vehicle has 82K on it and was owned by a school district, so preventative maintenance might have not been so good.
Thanks so much and hopefully this small history of the van will help better.
i live in downtown Portland OR, any suggestions on good shops would also be helpful.
Simon
