BDCarrillo
I'm on board with the pull heads and eval, but you oughta be able to narrow down a valve issue (if that's the case) by pulling the glowplugs and all of the rocker arms. Then shoot 20-30 psi of air in each glowplug hole. Any air rushing out the intake or exhaust will identify which valve may be goofed up. If you do find one, I'd start with pulling that head to see if a rebuild is even worth your time.
Rotating the motor backward and cranking the starter so that it "slams" was a horrible idea...
