I just recently purchased a 1993 F-350 Crew Cab that has a 7.3L IDI International-Navistar diesel with the stock turbo and 5 speed manual. The truck was apparently running then quit and sat for 2 years before being sold to me. I went threw the normal steps to try to get it running. 2 new batteries, new starter, fresh fuel. The problem is when you turn the key there is a big CHUNK. I thought it might be hydro-locked so I disconnected the IP and pulled all the glow plugs and same thing. When I put a breaker bar on the crank I can rotate it backwards like 7/8 of a turn before it halts again. Try cranking it and it just slams into the same spot (I can tell because I marked the spot with some soap stone). I have also tried shooting some PB Blaster down the plug holes to try freeing up any rust. I don't know if a valve is stuck or something like an injector broke and fell down in there but something is deff. keeping this engine from turning a full 1/8th rotation. Could a bad IP do that? What's everyones opinion on this???
