Headlight weird issue.
Thatoneguy
Boerne, Texas
Gents, so recently my headlights started being screwy. Basically, if I just pull the knob out, I'll get dash lights and rear lights but no headlights. But if i start pushing the knob in and out I can find the "sweet spot" and get lights up front along with dash and rear. BUT, regular headlights don't come on at all, high beams do come on. So what I did as a temporary fix was just point my headlights down and run with high beams on. But now its getting to the point where I can find that "sweet spot" but after a little driving the headlights and dash lights start flashing. Not a great thing to have happen at night on an freeway with no street lights! I did the googleing and all I could find was people saying their wiring harness had melted and caused connection issues, but the fact that when I mess with the switch itself and can get it to work makes me think that isn't the case and the actual switch is the culprit. Is my logic sound? Or am I an idiot again? Thanks in advance.
change out the headlight switch assy before your truck catches on fire. this is the #1 cause of death for our trucks. also, do pay attention to the connector plug and wiring adjacent to the switch.
Thatoneguy
Boerne, Texas
Holy crap man! Lol. So forgive my ignorance... But this is what you're referring to, right?
https://www.amazon.com/Motorcraft-S...ymm=1994:ford:f-350&keywords=headlight+switch
And can you clarify what you mean by the connector plug and wiring adjacent to the switch? Are you talking about the cluster of wires directly under the dash almost center that has whiteish plastic connectors? Sorry I'm bad with wording and understanding unless I can see it.
Thatoneguy
Boerne, Texas
Is it possible to set up toggle switches in place of this apparently problematic stock switch? Like one for dash/rear, one for headlights, and one for high beams? I dont care about keeping the dimmer, it can go. I only ask because I have a whole bunch of toggle switches I can use right now instead of having to wait for the stock switch to be delivered.
Thatoneguy
Boerne, Texas
Let me clarify... I know you can wire in a toggle switch. But the write-up I have found takes away your high beam.
Sent from my Moto Z (2) using Tapatalk
Thatoneguy
Boerne, Texas
Ok, thanks towcat! I have some relays on hand... How difficult is it to install relays for high/low beams and use toggle switch? If I can avoid ordering a part that is known for failure, I would like to.
if you're doing relays, do it close to the light.
i went LED instead. low amp draw/****** oncoming off bad. :D
Thatoneguy
Boerne, Texas
What write up?
Simple, add relay harness, replace switch and pigtail.
Well you do make it sound simple. Idk if I just overthink it or what... Pigtail is the part that actually connects to the switch right?
chillman88
Central NY
Yes it is. I ordered the kit from Bronco Graveyard. Plug and play. Look it up and you'll see how they did it
I think that one and lmc are the same kit. Order spare relays with it. They're a special kind. (Or lop them off and use normal relays lol)
I'm running the LMC Truck one in my 85, and it was a very simple and quick install. It was kind of like "Why was I ever worried about this? It was SO simple."
genscripter
Inglewood, CA
