Mikes91
I got a kit with some stuff in it for removing that yellow glaze that forms on the headlight lense covers of our trucks.
Basically, it works by sanding the outside surface of the plastic lens cover down beyond the damaged surface. Optical clarity is restored by sanding with finer and finer materials (sanding sponges as well as a couple of compounds for the final stages) until a clear appearance is returned.
VERY favorable results so far on the passenger's side lens--looks new (though I haven't finished the last 2 stages of fine sanding/restoring perfect clarity)--but I still have a bit of an opaque white haze on the driver's side lens. It shouldn't be on the outside--I've sanded that out pretty hard and can't imagine that hazed plastic would still be there.
Is it possible for these headlights to haze on the inside of the lens? Is there any way to pop off the lens covers without breaking anything?
It'll be nice to be able to see the road when this is done. Already there's a huge improvement--MUCH brighter lights than before (although the new headlight switch has a little bit to do with that). Best $30 I've spent in awhile.
Thanks,
Mike
Thanks,
Mike
