Ididrver, I've been where you are. I had my truck about 2 months before it blew the head gaskets and i had to put it down to do the work. I was really short on cash, working and going to school. The build took me 4 months and it was a real pain in the tail. We could all spend your money that you don't have right now but we should really just keep you advised of the essentials. This is my OPINION and not facts, but this worked for me. My feeling is that you will soon either do a real build or you'll get bored with the IDI and buy something else. To get you by for now and still have a reliable truck it is IMPERATIVE that you follow the reverse torque sequence to take the heads loose. THAT part is not my opinion. 7.3 bolts are troqued to either 90 or 100 ft-lbs memory is foggy... and if ou don't release that torque properly well you're going to warp or crack a head. Second, if Lindstromjd knows a good machine shop it is worth what it takes to get those heads down there. They need to be made flat if at all possible but it would be worse to mill them below minimum thickness specs. My bet is they will be within limits if the engine hasn't been overheated and you follow the correct untorquing sequence. You should have the heads pressure checked and magnafluxed and the valves need to be thoroughly looked over. A lot of 7.3s dropped valves. Now is the time to make sure this doesn't happen to you. If the valves aren't worn to the point of causing issues and they work right/aren't burned, I'd leave them alone. Messing with them can open up a can of worms unless it is done perfectly. You must get both the engine block and the head mating surfaces spotlessly clean. Here is where you need to be OCD about them being perfect...no old gasket material, no oil, be like Mel and make sure not so much as a fingerprint remains on either. You also need to get hold of a bottoming tap and chase the threads in the block. Put that thing on a T-handle. These guys tried to warn me but I didn't listen, so now a tap lives in one of my coolant passages. Granted it hasn't caused any noticeable issues but there it is. Lastly and most controversially, 7.3 and 6.9 headbolts are not TTY and you can reuse them, but you must clean them up. I used a die, some say this is wrong but mine have held up for going on 8 years like this. You may have a hard time finding a bottoming tap, icanfixall has instructions on how to make a standard tap bottoming. I didn't know how to do this so I just used a standard tap. It has worked but it was not correct. The studs are better but you don't have the money and you don't boost enough to even begin to worry about them. 7.3 bolts are good to 12 psi all day long. 15+ and you may be asking for it. If you don't have a lift, you're going to be asking for it...to damage your gaskets and possibly lose a fingertip also. I'd like to hear about handles for the heads. Ideally you take that heater box off and evacuate the AC system and also take the evaporator core off. This would give you plenty of room. Note that you'd probably need to tow it to a shop or have someone with a machine come to you to evacuate the refrigerant it is illegal and poor ethics to vent it to the atmosphere. You can rent a cherry picker for very reasonable rates at most any rental shop. I think you can do this the way that I did because this method bought me several years. I trust my gaskets pretty well even now after adding a turbo and having around 70,000 miles on them. True, what these guys are telling you is the best and most correct way but when you don't have much money you must focus on what is absolutely critical, that is 1) Torqe/loosening sequence 2) Surface prep 3) Making sure the heads are ok. Lastly take your time and enjoy the project and make sure small stuff doesn't get overlooked. (Flame jacket on)
