Hey all, I apologize in advance for the long post, but figured I'd give as much detail as possible.
I'm a semi-new owner of a 1993 7.3 with factory turbo. Having a few issues at the moment and have a feeling they might all be related, but I'm turning to the experts for a little help!
The current problems (in the order they've occurred):
-Began noticing a small amount of fuel leaking on the driveway after driving... a wet spot about 4 inches in diameter.
-Fuel leak has gradually gotten worse over the last couple of weeks, and is now about 2 feet in diameter.
-Took the truck out one day for about a 15 mile drive, stopped for an hour, and the truck wouldn't start. Took 5-10 minutes of cranking off and on (waiting for the starter to cool) before it finally started back up.
-Took the truck out last weekend and noticed it was putting out some black smoke and running a little rough. The truck has never smoked before.
-Now, every time the truck is warm, it does not like to start.
-Cold starts have never been instant like I hear from other people, but it usually starts within 10-15 seconds.
Where I'm at so far:
-Having trouble tracking the leak down. From the bottom of the truck, it drips off of the starter and also from the bell-housing.
-Looking up top, the filter/filter housing are dry.
-Based on previous posts, I placed a piece of paper under the IP while running the truck, but the paper came out dry.
-The return lines and injectors don't appear to be leaking, but I'm having difficulty seeing the back two on the passenger side under the turbo.
-Pouring luke warm water on the IP after getting hot makes the truck start like normal.
-Previous owner claimed the IP and injectors were replaced two years ago, supposedly still under warranty.
-My wait to start light usually only stays lit for around 2 seconds, even after sitting overnight. Doesn't even light up when warm.
Questions:
-Will replacing the return lines require removing the turbo? How difficult is that?
-Previous owner (a mechanic I'm still able to contact) suggested replacing the lift pump, could this be the issue even if cooling down the IP works?
-Any other thoughts? Really not wanting to pony up the money for an IP right now, but it might be the only option.
As always, I really appreciate any help!
Questions:
