grease on injector's????
larson
Springtown,texas
I'm ready to put my caps back on for the return lines as one assembly but I just wanted to check in with you gentleman first and ask if it is ok that I got grease all over the injectors' in the process of rolling on the o rings.
I cleaned off what I could but I know better than digging around in the top of the exposed injector. I'm assuming that the grease will just liquefy once diesel hits it. If not please let me know.
That grease will just wash out, no problem. Might get a little stutter at first on startup.
The grease will wash because of the diesel and the high pressure. Keeping things clean in important. Dirt hides in grease.
