gasket set
RLDSL
Diesel fuel abuser
Arkansas
I was looking at the contents of the Felpro conversion gasket set online here
Can anyone tell me what the circles in the bottom row are? any chance those are oil cooler o rings?
If anyone has bought the Victor Reinz gaskets from Napa recently, do they contain the same parts?
Also, if the engine already has the repair sleeve for the crank seals, does it still take the standard oil seal? I drawing a blank for some dang reason.
Thanks--------Robert
RLDSL
Diesel fuel abuser
Arkansas
Fel Pro Conversion Gasket Set?:confused:
That's how they break up the engine sets, Full set, Head set ( everything up top) and conversion set ( everything on the bottom that along with the head set makes a full set) why they don't just call it a block set, I have no idea.
I wonder if those donuts cover the 6 and 4 ring coolers, or only one of the two.
RLDSL
Diesel fuel abuser
Arkansas
If you check the things it fits it has and F150 listed so I'd wonder?
Those pull down fit lists aren't very accurate, but the gaskets shown in the set are correct for the engine
I just ordered the Felpro head gaskets and valley pan from Northern Autoparts for $35.99 for each head gasket pt # 9047PT and $55.99 for the MS96038 valley pan. Check out their site for other complete 6.9 or 7.3 ltr gasket sets. 1800-831-0884
