I sure as hell wouldn't buy that one for the price. The one on ebay for $49.47 is just as good. Both may mount horizontal instead of vertical. Azone, Advanced or O'reilly stock them for around $57, but you have to get the new 6 pole pig tail connector for either one. Connector is $11. IIRC. OEM connector is a 5 pole.
i have bought this. and ive installed it within 30 minutes.
no pig tail to solder and shrink wrap.
no wires to get crossed up.
simply plug in.
now for the real reason i purchased this item.
I WILL NOT USE SUB PAR FUEL CONNECTORS FOR MY FUEL LINE.
rubber hose and hose clamps degrade and are a source of air intrusion.
you have to either re-do your entire fuel system,
or you have to get the special unions to go from the nylon to rubber.
the 90 i did this on was super clean, and i got it super cheap.
spending 300 on this item, which was known to be bad, saved me alot of headaches.
or you can do mechanical ball valves, either way, without that part i posted, you will be modifying stuff.
just my $296.21 worth.
if youre gonna be jewish, put your damn ya mica on
