84TD
Let this be a lesson to you guys running old injectors, this was a sweet running IDI and all the cylinders were 400+PSI and the #8 got stuck open and killed that cylinder in 1 day. We had it pop tested and the shop said it would even hold 10psi.
Pulled the 6.9 with the dead hole out today with plans to hone and re-ring the cylinder. I am interested in getting opinions on what the minimum should be done while we are in there. Its my friends truck and he is considering a full build but its a time and $ issue, the truck needs to get back on the road in the next 2 weeks tops and this was an unexpected thing so there is just not enough time to save the $ to go all out.
If all the other cylinders are fine should I hone and re-ring those too?
Should I do the bearings?
Is it beneficial to lap the valves when replacing the valve seals?
Should I replace the oil pump?
I know in an ideal situation what all I would like to do to this engine(everything and studs too!) but my plans right now are to hone and re-ring #8, replace the valve seals and rebuild the oil cooler.
