Fueling issues?
Weldingman
Pennsylvania
Does anyone else have problems filling their tanks with diesel? My truck has dual tanks and they take forever to fill. If I try and go too fast the diesel just comes splashing back out at me. Any common mods to fix the issue?
Cubey
Van dweller
My RV's front tank has problems because of the very long distance from the filter neck to the tank if the nose is facing downhill due to the long horizontal pipe, which can happen sometimes if a station wasn't built very level. I never have rear tank problems, but the tank is very close to the filler neck so no long pipe like on the front.
Are you filling in truck lanes with big nozzles or in auto lanes with small ones? That can make a difference. Some stations are worse than others too, even with the smaller nozzle.
Clb
Another old truck
nannyfornia
:sorry:
Never heard of that issue;Pissedford had a better idea then fell asleap...
google harpooning the tank
tank vent mod
It seems like most gas stations (around here anyway) have concrete that slopes next to the pumps. I try to park with the driver's side higher than the passenger's side. You can park your driver's side rear wheel/s on a 4X4 block. Those are the simple, free things that I do. Other than that, go with harpooning the tank like Clb suggested. I eventually plan to do that with all of my fuel tanks.
Brian VT
Maine, USA
I filled mine for the 1st time recently. (truck is new to me)
1st place I went the nozzles on the pumps were too big for my filler necks. Only for "big rigs", I guess.
Next place was a normal station. Front filled fine at wide open (trigger locked). When filling the back one I kinda freaked out because there looked to be smoke coming out of the filler neck.
I have no idea what that's about. If it was actual smoke then I'm very glad that diesel isn't very combustible.
Weldingman
Pennsylvania
There the small passenger fueling nozzles
Clb
Another old truck
nannyfornia
Some pumps create foam\mist due to pressure and design.
You could be seeing the vent circulating the mist out the top...
Brian VT
Maine, USA
Thanks. I sure hope that's what it was. ;)
But it looked more like smoke than mist to me.
That's probably all it was. There's nothing that should be causing smoke for any reason when you fuel up.
Cubey
Van dweller
My RV has bigger necks but I have to baby it when filling up with a big nozzle, especially the front ank. I had to use them on my F250 a time or two with the truck's restricted size neck and that was a bit messy and slow. The foam is so annoying at random stations.
I did the Vent modification to my 86. Fills right up w/o spitting fuel at you or burping. here is one link I found.
Goat.
Cubey
Van dweller
Goat.
The article says in part of the "results":
Anyway, I went to the ‘Big Truck’ pump to fill up and was totally NOT impressed. It actually seemed like it took longer to fill up as the nozzle kept clicking off. However, I still have to use the ‘Little Truck’ pump for the real test since the fuel coming out of the ‘Big Truck’ pump just gushes out.
Big Bart
Tow&Slow
Newport Beach, CA
It’s a Ford thing.
Suggestions -
1) I insert and hold the pump handle up as high as I can, that usually works. If not drop down a little.
2) Add you diesel additives last. I find putting in first causes some foaming and the causes the pump handle to keep clicking off.
3) I also find there is a sweet spot, where the pump seems to be centered down into the center of the filler neck. Wiggle the pump in a circle and you will get what I am saying.
Sometimes the pump handle just won’t play ball.
Cubey
Van dweller
It’s a Ford thing.
Suggestions -
Nah the old Dodge van I had was similar. In Oregon, they just let me pump my own gas because i explained that it would backup if you don't baby it.
I always put in additive first but foaming is random. Just depends on the station. I've been to a station recently (small nozzle) that pumped so slowly that I had it locked on max and it was still slow. Some have no foam issues, others constant. Just one of those things.
dieselmainiac
