fuel tank upgrade
David94IDIT
Will a newer fuel tank from an f350 fit my 1994 f350? Has anyone attempted. There is a brand new tank for $85.00. What capacity are these?
This is from the CL add:
Ford 350 Super Duty Fuel Tank (From a diesel 4 door 4x4) Factory tank, new condition 0 miles. $85 Pictures were included in the add.
I was going to do that and the one I looked at was a no go, huge step up in the bed area.
I looked at that ad, it wont fit easy.
mankypro
Learning Slowly...
Boulder County, Colorado
I got a 45 gallon one from aerotanks - in retrospect I would have saved myself some $$ and just gotten the 35 gallon one that sells everywhere for about $150.00 less...
the one I got looks like this:
their model 1028B
There is also alot of space between the rear axle and the front of the bed on the inside of my frame rail where the front tank currently sits. If I ever get crazy I'm going to find someone to fab me up something to take up that whole area - should be good for 50-60 gallons. That and I'd figure out a way to mount it so it would be easy to get up there and drop...
Anyone know how to figure out volume based on square dimensions? I was asleep that day in whatever math class that was :)
jperecko
Diesel Ape
Boonies of SoCal
I think it was a Bronco that has a ~35 gallon tank... available for under $100 easy. I will try to stuff one of those instead of one of my tanks later on.
trj
MPG
Colorado
Anyone know how to figure out volume based on square dimensions? I was asleep that day in whatever math class that was :)[/QUOTE]
231 cubic inches = one gallon
Alex S
Jeoff
New West BC
231 cubic inches = one gallon[/QUOTE]
that is awesome I have a 1.9 Gallon engine :D
LCAM-01XA
my very own hell
The fullsize Ford cars from 1979 to 2002 use a 19-gallon tank that lives between the frame rails right behind the rear axle - want me to go crawl under mine in the garage and measure it up for ya tomorrow?
mankypro
Learning Slowly...
Not for me, I have a 16 gallon front tank - I'm just dreaming about having a large front tank.
Administrator Moderator
mankypro,
Something you may want to look into, my Dad has a 94 E-150. It has a tank that is "front mounted" and has a capasity of something like 35-40 gallons. It has been a while since it was up there but it mounts in a similar position to a factory front tank. Also, on the rears my Ex has a 44 gallon rear tank. Not sure if one of those would fit in the rear of an older truck...... just a thought.
RLDSL
Diesel fuel abuser
Arkansas
You could just get you one of these critters. Get you about 1500+ miles in between fillupswhen towing heavy :D;Sweet
I got tired of those rediculously small factory tanks. Basically when towing heavy, 100 miles usable on the first one and once you've flipped it's time to start looking for fuel cookoo Adds an extra half a day or more to every trip.
mankypro
Learning Slowly...
I have a 45 rear, a 16 front and a 100 in the bed that gets me a one way trip with some to spare. With a 50 gallon front I could round trip and not have to fillup :)
sassyrel
iowa
i used a 160 gallon one for my truck--and coated it with 1 inch of spray foam--now im going to add the heater lines to the top that were already there--so my wmo is heated--and wrap the lines forward--year round use!!
Andylad13
DieselBoy
Connecticut
I've heard about the bronco tanks working before, but im not sure how easy they fit. i hope they work good because i would like to do that rather than getting a $200 big rear tank.
Fozz
Camarillo, CA
What about just getting another front tank from a truck at a junk yard and mount it opposite your existing front tank? Granted you would have to get creative with the plumbing/filler. When using larger aft tanks, you lose the spare tire - right?
crispy74
