Diesel JD
Hey guys, I recently replaced my fuel tank selector valve/m,otor assy and associated wiring, the front gauge works and I have verified the correct voltage to teh appropriate prongs and no others. However, when I flip the dash mounted switch, nothing happens, the gauge changes not at all, and the polarity to the valve motor does not reverse as it should. Now I did replace the Ford valve with an Echelin universal unit from NAPA, and Echelin specifies that an always on dual position switch should be used, so I guess I have a couple of questions 1) how far do I have to take teh dash apart to work on the dash mounted switch, and 2) How can I confirm that it is in fact the switcha dn/or associated wiring,a nd not a break in the wiring somewhere between the valve and the switch and 3) Can I just replace it with any good 2 position switch from teh hardware store...or is there an even simpler solution...is there a fuse I can check which controls the switch(not teh valve and gauges cause they work). Thanks,
J.D.
J.D.
