HammerDown
Well, it appears my rear Fuel Tank has a slight leak where the rear support strap makes contact with the upper outer corner.
(not so bad the Fuel it hits the ground...more of a slight weep)
For sure it's NOT the Sender O-Ring or related connections...that area is bone dry.
So, if I drop the Tank what's my best way to fix what may be a small wear/rub hole?
JB-Weld sandwiched between a sheet-metal patch or ???
Is an 'EXACT' replacement Tank even available for my 1988 F250 Super Cab?
Local Salvage yards are not an option...they scrap vehicles this old.
Thanks for any feedback.
