Fuel problems
Ray-F250
Georgia
hi I had some injection pump problems and got a new pump and installed everything was running fine and now im breaking down again it’s like I’m running out of fuel so I have fuel in tank I pulled the fuel filter off and it is half full like the pump is sucking it dry I fill filter up with fuel and runs fine for a little while and then it happens again any suggestions would be greatly appreciated
Ray-F250
Georgia
I haven’t long been replaced the lifting pump I wonder if it could have went bad in such a short amount of time but I will check both of those things and see thanks
It's possible that the lift pump could be bad. It's also possible that your shower heads broke off and you're sucking air at less than 1/4 tank.
