Interesting about how these things don't run right with too much fuel pressure. I'd never thought about it like this.
Mel, sle2115, & you other guys have posted some stuff here that makes some things fall into place for me.
I had just figured that concerns about over 7psi pressure had more to do with blowing return lines loose & off, etc.
This brings my question. & I'm not going against "tried & true" methods & experience....I'm sticking with Red.
But I have wondered about volume of these Reds, Blue, Black, Mallorys, Carters, etc in relation to the pressure.
If for some reason someone running "offbreed & inconsistent fuels" like WVO & other narley stuff & wanted more return flow back to tank to help with fuel heat in tank, then running one of these higher pressured-higher volume electric pumps won't achieve much?
I guess what I'm trying to put into words is, let's say an elect. pump at 15# supply's too much press. for IP to handle. I got that.
But wouldn't the higher press.=higher volumn that's got to go somewhere.....back thru return? & overlooking injector orings leaking, return line connections, line size was big enough, & everything being equal & no leaks, wouldn't the extra press/fuel go on back thru returns?
Probably have to have a different way....partial IP bypass, to get extra fuel back thru return system.
Anyway, just been wondering for long time about this. Wondered about how much volumn a stock lift pump puts out at different RPM's also.
I'm supposed to help a friend work on & modify his fuel system. I may just undo his return & do some checking of return output at diff. rpms.....catch it in a bucket & time it. Then I'll know. Do it on his rig instead of mine & tell him "it's part of requirements of this job"
