Fuel mileage.
Selahdoor
Index Wa
1992 F250 7.3NA E4od trans, With lockup torque converter.
With a brand new, (Rebuilt), trans and TC.
What do you think the fuel mileage should be?
By the way... Before this truck sat for 5 years, the TC was not locking up, and it was STILL getting 15MPG.
Christian9112
California
15mpg sounds about right for an f250 empty with normal throttle. i would imagine highway miles would be less with TC not locking up than LA traffic
Oldiron
Windsor, CO
I just installed a Moose Jr pump and injectors and switched over to an electric l.p. on the truck in my signature. I have been getting a consistent 15.3 for daily mountain driving. In a couple weeks ill put about 400 highway miles and see.
Cubey
Van dweller
My 87 F250 6.9 NA C6 3.55 gets about 14-15 hwy with a short, light camper (just a cap, not a slide in) with a rebuild trans a few years ago, dunno how old the IP or injectors are. Engine likes to use oil but not "excessive" for an IDI, I guess.
Cubey
Van dweller
This mod will drop you down to about 6.6mpg. Lol
Whatever that is.... I don't even get that bad in the motorhome! Except maybe with winter blend fuel while climbing mountains. It gets about 9-9.5 hwy in summer. It's getting about 8-8.5 right now. Could be the new fan clutch hurt mpg too, it dropped immediately after putting it on, but it coincided with about when they start using winter fuel, late Sept/Early Oct.
Oldiron
Windsor, CO
It was the stock intake tube. I was hauling a 35's 5th wheel up the pass. I dont know if it happened on a down shift when the turbo spooled, but it sucked it inside its self. Huge drop in power and mpg.
Enginerd
Vilonia, Arkansas
I have 93 n/a e4od 4wd and a 3.55 gear, and I've been getting 16-17. I also have the front brakes dragging a little more than they should though. I'll be replacing the master cylinder next. I just straight piped it so we'll see if the mpg bumps up. But I do feel bad with that straight pipe at 4:30 in the morning going to work so I don't know how long it will last...
Jason1377
Arkansas
Not to sound dumb but how do you go about figuring milage out? My rig is a stock n/a e4od automatic 2wd 1993.5 f250 stock rims/tires and when both tanks are fuel I can go roughly 375 miles using both tanks not letting either one hit the last white line before it meet the dreaded empty red line.
Sorry my punctuation sucks spelling sucks for a fat fingered dyslexic man
Selahdoor
Index Wa
To get somewhere close to knowing what your fuel mileage is...
First, you have to be sure your odometer is correct.
Second, you have to fill the tank up the same way, every time. In other words, hold the filler in exactly the same place. Hold it all the way open. Or part way. Etc. Stop the first time it shuts off. Wait till you know the fuel is pretty much to the top of the tube. Etc. But do it the same, every time.
Now... Go fill up. Write down the mileage.
Drive.
Every time you get fuel, fill it all the way up. (Remember. Do it the same way every time.) And write down the mileage.
Figure out how many miles you drove since the last fillup. Divide that by the amount of gas it took to fill up.
After several fillups, you'll be able to determine an average. That is your fuel mileage.
Christian9112
California
odometer after first fillup (Example, 1,000,000) keep note of this
Odometer after second fillup (example 1,000,140)
From the first fillup to the second fillup you have driven 140 miles.
Second fillup gallons (example 10 gallons) it would say at the gas pump. keep note of this
second fillup miles - first fillup miles = total miles driven. (140 miles)
gallons used for the 140 miles you have driven = (10 gallons) your tank doesnt have to be empty. just keep note of how many miles driven and how much fuel was used.
miles driven (140) divided by gallons used (10 gallons) = 14 miles per gallon.
