Fuel leak at fuel filter
DaleInTN
Cleveland, TN
Sure it does. If they come on when you turn the key to the on position, then they work...but polarity has to be right for them to come on
Well if they come on briefly with the key, then yes. Shouldn't be a problem, you didn't say that earlier though. You said your truck doesn't have a fuel filter light.....
DaleInTN
Cleveland, TN
I'm not aware of a fuel filter light. I replaced all the dash lights, so when I take off the filter head, I'll ground out that sensor on the top and turn on the key to see if a light comes on and stays on.
I have an '89 and the only light I have that I'm aware of pertaining to the filter is the water in fuel light. If you or someone else can tell me what light should come on when the filter needs to be changed, that would be great.
Anyone have a picture with the lights on both sides of the steering wheel?
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
Dale,
Here are a couple pictures from the dash of my 88, same dash as you 89
Here is the light on:
Here is a picture to show better where it is, in relation to the other diesel specific lights:
I didn't get into the cab fast enough to see the bulb check (bad actuator, have to hook the negative cables up), but I took the plug off the sensor on the filter head and grounded it to force the light on.
DaleInTN
Cleveland, TN
Thanks, I've never seen that light on, even for a diagnostic at start up. I will definitely ground it out to make sure everything is working properly.
Here are the pictures I took earlier. The water in fuel was the only light I was aware of
dogdanblue
