Fuel leak at fuel filter
DaleInTN
Cleveland, TN
Just picked this up. Any reason this won't work?
DaleInTN
Cleveland, TN
Cool. I'm hoping to work on my f350 Friday, tomorrow is spoken for. I have to replace the radiator in my Freightliner. It's pretty much a full day
DaleInTN
Cleveland, TN
Ok.
I don't have a change filter light, unless that sensor can control the water in fuel light also.
What year is your truck? If you have this wire then you have a dash light indicating you need to change the fuel filter. I have only seen my filter light come on once. Even then it slowly illuminated under full hard throttle. The way this switch works is it measures a vacuum in the fuel delivery to the injection pump.
DaleInTN
Cleveland, TN
I replaced all my dash lights with LEDs, I'm pretty sure the bulb is good. When I fix the leak, I'll ground that wire with the key on and make sure a light lites up somewhere.
Thanks again guys for the help
DaleInTN
Cleveland, TN
I checked them all in a spot that lit up with the headlights before putting them in the current spots. I wanted to make sure the polarity was correct.
dogdanblue
