fuel gauge always reads full
Coopons
100 mile house, bc, canada
Ok guys and gals, I have a 1996 F350 ccsb with a 7.3.
Rear fuel tank always reads way pass full does move until I switch tanks then it reads as it should
Tried a spare sending no dice. I verified that it worked by checking it before I pulled from donor truck
Any one have a wiring diagram for the tank wiring?
Will a fault tank selector valve cause the gauge to not read correctly?
The valve does switch back and forth from tank to tank
1/2 the time ive had issues with the tank readings, its been the fuel switch valve.
so it most certainly can.
reading full is a ground issue.
reading empty is a feed issue
  • Like
Reactions: Clb
Clb
Another old truck
nannyfornia
And then go **** on Henry's grave
My front just stopped working, at least it's the easy one...
Lance
