Front headlight question?
92fordidi
burleson tx
Hey guys i was wondering i have a 92 F250 4x4 single cab and i wanted to install either 99' superduty HALO headlights or 08' superduty HALO headlights, i was wondering if anyone has seen this or knows how to fabricate a fitting? Thank you
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
Wow... that is quite a jump. I am not sure how that would work. Is this just a "light bulb" type change or are you talking about the entire housing..... Just a bulb change if they run the same bulb, which I think they do... a 9004. it is doable. But to mount a superduty headlight into an OBS truck.... that would be a challenge. I have an 03 Superduty (Excursion) and the headlight housing on it, vs an OBS headlight is very different. You may be able to swap over the housings, and the buckets from a superduty, but they would not match up very well with the lines of an OBS. Also, doing an entire doghouse changeover would probally be out also since the SuperDuty is much bigger than an OBS...... would present a neat chalenge, and if decide to do it, lots of pics please....
Can't wait to see what you do with the back headlights. :D
OK, yes.. that's just me being a smartass. LOL
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
thats not a smartass comment at all. at the bus garage i worked at half of the drivers called the reverse lamps rear headlights. took me a second when i first read that they had a rear headlamp out.
Optikalillushun
Coal Region, Pa
there actually was (possibly still is) a company that makes a conversion kit to use SD parts on the 92-97 F-series trucks. i have only see two truck with the swap and it was both of the companies trucks. lemme do a little digging and see what i can find.
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
92fordidi
burleson tx
Personally i just like the look of the RECON 08' superduty HALO headlights and i measured it out and it would be tight but if you got some sheat metal and painted it that would make up for the empty space thats there...any other options??? oh and thank you all for your comments ill let ya'lll know if i decide to...oh one other thing the reuck is a flatbed os i already have led taillights
Diesel_brad
Dunce
gilbert pa
So you want to use the WHOLE 08 headlight housing? Not just the bulbs?cookoo
FAIL!! that would look like CHIT in my Opinion
oilburners
Beverly Hills
Not to steal the thread, but does anyone have a report to offer on replacement stock headlights that don't suck walnuts? I've got two trucks here and even with new (stock) housings and bulbs I can't see anything at night. The cars behind me project my trucks shadow in front of me. My lights look like candles compared to the more modern cars and trucks. Do the Eurocrystal lights mentioned above work any better?
if the plastic on yours is faded or cloudy, it's time for new housings.
I have a set of DOT aftermarket units on mime and they lasted for five years before starting to develop internal checking. plus side is the silvering had a dark tint to it when the lights weren't lit, so the effect was almost like a blackout appearance. I'd try the euro style as long as they are focused properly but I don't think they will last as long as the DOT style before they lens start having problems.
The Warden
MiB Impersonator
I firmly agree with you about focusing them properly!! And, why do you think the lenses on the Euros won't last as long? FWIW some people on the TDIClub forums were talking about this stuff...they were talking about it doing a very good job (if applied properly) of protecting plastic headlight covers from scratches, rock damage, and such...I'm not sure how well they'll work with UV protection (which I'm guessing is what causes the yellowing), but figured it couldn't hurt to try? Of course, this won't protect the inside...
Diesel_brad
Dunce
gilbert pa
The bad part about some of the aftermarket housings is that the chrome inside tends to blacken and flake off leaving very little reflective surface
Fordsandguns
Fords Rule
Eastland Tx
I wish there were a way to get glass housings. It would solve all the yellowing problems. They would probably break easier but I think other than that they would be great.
Staff online
