Front bumper strong enouph to be towed?
GTFD
San Diego Ca
Are the front bumpers strong enouph to attach a tow bar for towing the truck 50 miles across the county? The mounting bolts look a little marginal in size for the job. Any experiences? Thanks
the long and short of it.......
NO.
if you are going to flat tow your truck you need to mount the brackets to the frame. If you have a 80-86 truck, that is the easiest to work with. 87-91 requires the removal of the bumper. 92 and up requires some serious creativity since the front of the frame is now a "crush" zone.
92F350CC
Ford Man
Las Vegas
Flat towing is a no no if you have a ZF5, unless you remove the driveline. On that thought, Towcat, is it possible to flat tow a truck with a ZF5 if it has 4x4 with the t-case in neutral?
sle2115
NRA LIFE MEMBER
Southeast Ohio
I've always been told the same thing about automatics as they parts might be moving, but no fluid pump running. That being said, I don't know that 50 miles would hurt either...then again, who knows?
I'm not sure, but I think the oil pump is on the input shaft side in the xfer case. Not sure though. Somebody who has had one apart should comment. If it were on the output shaft, surely that would work.
Cat_Rebel
Does not compute
Wouldn't you like to know
What are you going to flat tow your truck with? I wouldn't go any smaller than a 3/4 ton & up. Remember that flat towing is diffrent than a trailer.
My new bumper has the brackets welded onto it for a tow bar. The last truck it was on (83 Toyota) was towed that way all the time. That being said I'd rather get a trailer & throw it on there just due to the overall size & weight of it. I might get around to removing the old brackets one of these days.
DowneyB
Professional
Spring Hill Kansas
Flat towing is when you just hook a tow rope to it and go right?
Why are you not supposed to do that when you have a ZF5?
subway
be nice to the admin :D
York PA
ask tonkadoctor about that one:D he had to replace his rear housing and everything in the ZF is attached to the shaft so he had to basically rebuild the whole thing. the rear bearings dont get lubed properly if the rest of the transmission is not turning like it would be if the truck was running.
h2odrx
Anti-O
Coastal Neckville, NC
Give us more information, what is towing what???
