snaponprofile
For those of you with a ZF5*IO need pics of ZF crossmember!!!*.......
i got a couple questions for you. I stated in another thread that I am going to be doing a zf5 swap and I picked up my zf5 from a 88' f250. I had the pleasure of seeing it all work as the tranny was still in the truck. Thing is, the truck had a bad case of firewall flex, bad bushings, and the Master cylinder was going. So the clutch had to be buried all the way touching the floor for it to go into gear. Once I get it in my truck, seller said it would operate normal? Another thing, how much play should there be in the shifter when it is in a gear?? Also, this truck had 160K on it, Is there anything I should look for/replace before it goes into my truck? The transmission was dry underneath and it looked pretty good to be honest. I'll post pics once I get it home.
Also, I want to solve the problem of bad bushings and I read about a hiem joint(sp?)? Where would I get this?
Also, I want to prevent firewall flex, I thought I remember something about a stabilizer plate for trucks that were flexing?
Thanks
Thanks
