for serpentine belt trucks only.......
this is an item every serpentine belt truck owner should have in his/her spare parts toolbox. should the situation arise you seize up your air conditioner pump or pulley bearing, this will save you a very expensive tow or a ruined trip. this is a motormite/doorman part #34184 and replaces where the AC compressor used to go. yes, you won't have AC, but it beats being stranded.
part number is already in the "Parts Bin" in the tech articles.
subway
be nice to the admin :D
York PA
I keep one behind the seat. Wish I had an idler to swap out for any accessory that could go bad.
Brimmstone
Used to carry one in the wrecker just in case. Have one already sitting for the new service truck when I get done rebuilding the stroke in it.
I see these all the time in the wrecking yards I shop thru. Hmm.. I wonder if there is enough room behind the rear seat...:dunno:angel:
lotzagoodstuff
Carmel, IN
Looks like about $40 brand new. Icanfixall, what would you pay for one of these at the wrecking yard?
Calvin: you are a spare parts ninja ;Sweet
D.A.V_Oil_Brnr
M88 Junky
Eugene, Oregon
ermmm...
Just a thought here.. But, uh.. lets say you lose the pump on the freeway and get stranded... Some vehicles you can get away with having a shorter belt that still fits the serpentine path. For me the belt would be preferable to standing on a freeway removing an ac pump..
The pulley is still nice tho. If I was serpentine i would carry it.;Sweet
there's not much or a way to get around this. if there was, Ford would not have went through the expense of designing such part. this is on the AC delete vehicles. I just happen to give it a expanded use;Sweet
rjjp
Needs to go test
Clare, Mi
Just to add to what Calvin said on this, if the **** did hit the fan on the freeway you could most likely get off the road before having to do it.
P.S. These trucks will snap a belt and keep running, it can be witnessed when the belt slips off and gets wrapped around the crank pulley at idle.
Dsl_Dog_Treat
Decatur,MI
One more reason to stay with my old v belt setup. Chucked an A/C belt which took out the alternator belt but left the P/S pump belt so I could steer and stop. :D
TWeatherford
Flagstaff, AZ
I bought a similar part at autozone for $40 when my AC pump seized on me. When I finally get my AC back I'll be keeping it in the toolbox, just in case.
