For anyone around NW Ohio that wants to start using WMO...
Ironman03R
Risingsun, OH (NW OH)
Since my truck is not running and hasnt moved in over a year now, I have no need for my WMO filtering setup. I plan on building another one down the road so I'm keeping my filters but if someone wants the tank and setleing barrel they can have it.
It is made out of a 35-40gal fiberglass pressure tank and has a valve on the bottom that you would attach the filter of your choice to. It works on gravity feed if you elevate it or you can pressurize it with 10psi and it will flow steady. Also can have the 55 gal plastic drum with a hole cut in the top for a 5gal bucket screen.
Theres even a little oil in the botom of each.
I would rather see somone here put it to use than throw it out. I could use the garage space so its gotta go.
I'm located in Risingsun OH, 2 miles of US-23
