For a friend of mine...Oil pressure questions
Diesel JD
Gainesville, FL
On a 2001 7.3 PSD in an E350...where are the oil galley ports where he could connect a mechanical oil pressure gauge? Are they the same places as the IDI? What size plug is in there? The backstory is that his factory oil pressure gauge apparently quit working. It shows no pressure but the HEUI fuel system still works fine and there is no check engine light nor any scary sounds so we're working on the assumption it's a bad gauge not bad bearings or bad oil pump. Lastly, what should the oil pressure values be and at 233,000 miles would any of you PSD guys consider changing the oil pump as a matter of course (PM) instead of because it is known to be bad? Thanks for the help for a basement guy,
JD
94f450sd
somewhere,ma
same place as the idi on the oil cooler.the oilpressure sensor is in the HPOP reservoir in front of the fuel filter housing.ive never heard of a PSD with a bad oil pump.should be around 10-15psi at idlewarm.and 40-70 psi at 3300rpm warm
I think the oil pressure sensor is the gold one on the HPOP reservior to the left.
Diesel JD
Gainesville, FL
Thanks Rich and Bill. I will pass this info along. I bet the stupid gauge is just bad or at least I hope so for his sake. I also think that 7.3 has a lot of life left in it, it sounds really good running.
