jlpdemag
Hey guys some of the folks at the IH site I am active on suggested I ask for your help on this. I just purchased a used 1988 7.3 IDI for a project Scout of mine. The motor was in the truck when pulled but the trans and tcase were in the bed of the truck when the PO bought it. I bought it all. The motor had the Dual Mass Flywheel on it when pulled. The springs are trashed on it, and from what I have read this was the stock application. In the bed of the truck with the transmission is a Solid flywheel. It will bolt up and also appears to be correct. Question is how do I know if it will work or not? The only numbers I can find on it are as follows:
1803217 C1 B
also has O221L
If anyone can shed light on these part numbers/casting numbers that would help a ton.
John
1803217 C1 B
also has O221L
John
