ferrellmedia
I just finished replacing my engine with a rebuild which I know NOTHING about.
I took a chance and bought the engine from a guys daughter who passed away and this was a rebuild he had sitting in his shop. So I know nothing about the specifics.
In the mornings the truck just spins and spins, (brand new batteries) and puffs what smells like rich diesel smoke, color is mix of blue and white. Eventually the truck will roar to life with a LOT of black smoke and missing somewhat like it's flooded.
New tanks, new fuel pump (from NAPA) and new injector pump, injectors have 140k miles and have not been tested.
I live in south florida and the temps never get too cold, however, I allow the glow plugs to cycle prior to starting.
Cold compression test with US GENERAL harb frieght test kit thru the injector hole returned 250/275 on all 8 cylinders.
Could this be the fuel prime leaking down after sitting all night?
Could this be new rings not seating properly and not having enough compression to start until they get hot?
Could this be worn out rings and the rebuild is really only pulling 250 compression and this is causing the hard morning start?
Could this be timing related? I have the IP mark set approx 2/16" what I think is advanced to the passenger side of the trucks engine relative to the mark on the gear cover.
The truck runs REALLY well once started and pulls nicely and only smokes when floored.
And I've let it set for 1.5 hours after running and it starts fine, really fast, just a couple of cranks and it starts right up.
It's only that first morning start where I have this issue.
Any steps to rule anything out or just take it to the "stealership"?
I'm also wondering why my "wait to start" light is no longer working and wondering if I've got a wire missing or cross wired, but took pictures and there really isn't that many to mess up.
Any help is appreciated.
