Finished Turbo Install
PM Typ4 for the 411 on these turbos...appears he is the quintessential local guru....easier to PM and dialogue than ask here.
@typ4 works sometimes to draw him in :rotflmao
Few things, I have no more of the turbine housings for sale. Only had 3 to go and they went quick. I have an aftermarket silicone boot company making some new airbox to turbo boots. first one should be in hand soon.
I also have 100 nos drain grommets on hand.
Still Strokin
Hamburg, IL
I wish I knew production numbers from ATS on the turbine housings. Their probably starting to show up in junkyards
catbird7
PA
I think Still Strokin is the guy I bought this from??? Anyway it was a good buy and last winter the entire engine was removed and reinstalled in my current truck.
Still Strokin
Hamburg, IL
I think it was. That was the most complete kit I've ever sold and probably the nicest . Excluding the home made down pipe it had every last nut bolt washer o ring and fitting
catbird7
PA
It was an excellent "buy" for me as I was very close to pulling the trigger on a new banks sidewinder. The turbo I received from you was rebuilt by International, and I upgraded the downpipe to 3" stainless. I has worked flawlessly, THANK YOU!
Still Strokin
Hamburg, IL
Cat bird is the truck in your avatar the one you put the turbo on? bout a twin to mine only mine is regular cab. yours is sharp
catbird7
PA
Yes sir, that be it. Really happy with how it turned out.
tke395
