Finished my York pump and AC mount!
alienturtle
Human
Ripon, CA
here is my york pump and stock ford AC pump mounted back up. i had a v belt groove on my fan pully so i used that to run the ac and york pump. solid as a rock and the belt adjustment works great. just need to plum it and have ac lines made. I need to get some pics of it mounted and painted. i had to take it off to get it ready for paint. take a look.
alienturtle
Human
Ripon, CA
im not sure how it would work on an idi block. the cummins block is of total different shape. it would just be a matter of designing a brackat with the same sort of setup. ill get some pics tonight when i get it all painted and mounted up.
LCAM-01XA
my very own hell
Can't do the same arrangement with an IDI, we have the PS pump under the A/C compressor. There is however enough space to squeeze the your next to the A/C compressor and above the pump, Heath posted pics and drawings with measurements of his setup not too long ago... And that reminds me I still have to swap my 115psi blow-off valve for the 150psi one, maybe tomorrow I'll do it if it don't rain.
