6 Nebraska IDIs
- Joined
- May 27, 2007
- Posts
- 4,247
- Reaction score
- 15
I finally got sick of my brown truck not starting, so I stuck out the -2 degree weather and installed my new set of battery cables. WOW does it start faster!
While I was in there, I moved the small frame ground on the passenger side crossmember from directly under the manifold, to the front side of the crossmember, WOW did that make the job easier to install that bolt! I also noticed oil on the block at the rear of the passenger head seam, as well as at the front of the same head seam. So Im guessing I've got head gaskets going bad.
