homelessduck
After bleeding the lines it fired right up ! It idles smooth, but doesn't rev very smooth. It will rev up if you give it throttle slowly though, and you can really hear the turbo !! It probably still has air in the lines and needs to be timed (?) . The transmission seems to engage properly, but the linkage needs to be adjusted. The catch can works perfect but I need to run it behind the cab ..it's routed near the driver - side battery and I'm sure it will be smelly.
Hmm, what else ..... YAY!
Thank you guys for all of the help !!!
