Fan Clutch or Radiator
beretzs
Midway Park, NC
Darrin, do you have the info for the MSTec fan clutch? I have tried to search it out, but don't get any hits. I still need to do the real test on the fan clutch, but last night when I turned the fan, it spun freely, but I could not just whirl it around. I am thinking it is more the radiator that is old and full of crap. Scotty
F350camper
BOOST!
USA
This is my opinion on the fan clutch. Others may disagree, but this was my experience. You have to think of them wearing out much like an IP does. It still works, but degrades very slowly over its life. So slowly in fact, that you really don’t notice how much it has degraded until you replace it. I noticed a huge difference when I replaced mine.
beretzs
Midway Park, NC
I think my best course of action is to get the radiator cleaned and then put a new fan clutch on. Hopefully, with any luck, that will fix my problems. I think the radiator just needs a good cleaning. Any idea on how much something like that would cost? I want the radiator clean, no gunk, crap or **** in it. Scotty
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
just curious what is different with this modded fan clutch?
It kicks in at a lower temp than the stock one, I believe it is around 212 deg. I will finally get to test it out next Saturday as I will be pulling the 5ver for the first time since installing it.
beretzs
Midway Park, NC
How did your new fan clutch do? I can get a motorcraft fan clutch for 168.00 so I am just wondering how much the new fan clutch has helped. I was fine with the way the old clutch worked, when it worked. I may take it back out in the hills and see if it even kicks on. If I don't hear it, I am putting a new one on ASAP. Probably just go with a stock unit, unless someone preeches how good the MStec is. Scotty
bob123456789
