typ4
I use neversieze and tighten it tight, never comes off , so ,whatever your poison , pick it.
yeah, like I said, I would love to put on an electric fan. I may look and see if they are available anywhere locally and the cost. You are right, now is the time to change it, I just don't know if there is room in the budget. I'll see what they run.
When you guys say "windstar fan", I'm assuming it's the e-fan from the Ford Windstar, right? Any make/models I should look out for?
i use the permatex red on my front arrowcraft dually wheel adapters.iv had to remove them a couple times for front end work.the first time i don't recall what i was doing,the second was to put on some upgraded rotors.the way their made,you can't even use get a socket on 'em.have to use a wrench.i just put the wrench on,and smack it with a 3lb and they free up and turn right off.not easy or anything cus that's what the stuff is for lol,but you don't need to be hulk hogen to turn the wrench or anything,and grabbing the torch was never a thought either time.so im not sure where the fear is with red loctite personally,im not afraid of the stuff.it's not jb weld type stuff or anything in my experience.
that said,i still think e-fans are the way to go,especially with a new rad going in,cus it's so easy to bolt on the windstar fan to a rad that's out,to get your bolt holes all drilled/tapped or self tapper holes made and then set the assembly in after the rad is in.couldn't ask for a more perfect time for the upgrade.
I have the tool that goes in my air chisle. Thats all I ever use.
Putting the electric fans on is not as easy as just installing the fans. You will also need to upgrade the alternator, and also wire them into the A/C system if you have one and use it. Been there, done that.
