Oil cooler is mounted after new rings. I made sure there were no burrs/dirt and lubed it up but still had to press it on. Hopefully no leaks!
Also installed the clutch set - flywheel was resurfaced, new bearing installed on it, added grease to bearing, new clutch disk and pressure plate. Blue medium loctite on all the flywheel bolts.
Just need to hose off bell housing, clean and grease the joint on the clutch fork and throw the new throwout bearing on there and bolt it all up. but I gotta get the engine off the stand first, the stand bolts on to where the bell housing goes.. Then attach the turbo oil feed line to the block by the oil filter.
Then I need to bolt on the exhaust y-pipe and downpipe, throw the motor mounts that I fixed up back on, swap over the IP cold advance solenoid stuff and toss it in! Add oil and crank till I get oil coming out the turbo oil feed and then attach it to turbo. Then I should be ready to rumble after I put the radiator support, radiator, head lights, and maybe bumper back on ( I got a front mount hitch but it doesnt fit this truck (too narrow) so I'll probably be ordering some thick square tubing and making cutting/welding it. For a winch
Sounds about right?
