Working on the '93 F350 I picked up a few months ago. The PO DESTROYED the terminal end of the engine loom, including the glow plug controller wiring. I pulled the engine loom off of a 1990 donor truck. The 12 pin connectors are identical, however the wire colors and configuration are not identical, including the heavy gauge glow plug controller hot wires, which are absent in the '93 loom. I've got the donor loom cleanly connected to the engine. I cut the pigtail off the donor chassis to splice onto the cobbled up mess the PO created. My question is, has anyone here tried this maneuver before? I need the '90 and '93 wiring diagrams to confirm that the connector wire locations are the same. Thanks in advance for any help.
