EGT Probe Questions
Worstenemy453
King George, Va
Im installing my gauges tomorrow and had a question.
Where do i put my probe ?
I have one designed for a gasser so it is a hose clamp style instead of a threaded but it will work until i do a turbo. Do i put it in one of the cylinders on the manifold or do i put it down past the collector piece ?
91/2 7.3idi
BarnyardFabrication
Salt Point, NY
drivers side exhaust manifold. i have the same type of probe, but i screwed mine up and it leaks. but the is a spot there that it should work no problem
91/2 7.3idi
BarnyardFabrication
Salt Point, NY
ive always been told to keep it as close to them motor as possible. this way you get a more accurate reading.
gatorman21218
Ashland VA
I drilled a 7/16 hole on the top of the exhaust manifold. I tapped 1/4 NPT and then threaded my thermocouple in. Its easier to "step-up" to 7/16 by using smaller sizes (ie 1/8,1/4,3/8 etc)
Diesel Max
93 F-250 4X4 - 7.3
New Mexico
Driver side exhaust manifold on top about 1/2 way between the front and back. Seems to be accurate and works great.
Diesel_brad
Dunce
gilbert pa
Now i have 3 different answers ?
My instructions say drill a 1/4" hole and clamp it up.
The instructions LIE. They also tell you to put it post turbo,when you have a turbo. If you do that By the time you get a reading post turbo your pistons are melted into the pan. Put it in the manifold toward the rear to get an average reading of that one bank. If not in the manifold right into the y-pipe where it meets the manifold.
If your probe is the clamp type then drill and you clamp it. If it was a thread one you would drill and tap
gatorman21218
Ashland VA
IDK about a hose style I am just telling you how I did mine. My probe was 1/4 NPT. Thats pretty much the only way to go if you want it to be in the manifold. You can put a hose style in the crossover pipe just remember you want this thing as close to the cylinder as possible to get the most accurate. The general consensus though is if you in the crossover pipe within a few inches of the manifold then you should be fine. Just dont put it back by the muffler (if you have one) or something ignorant like that
Worstenemy453
King George, Va
I was thinking drivers side manifold, first cylinder at the front, and it would be about 1" off the side of the head.
NMB2
Dunce
Ft. Lewis, WA
mine is on the passenger manifold halfway between the rear cyl and flange.. Seems to get a pretty accurate reading.
placidoert
