1991 2wd E4OD. NA 7.3. Truck is used to tow my 5th wheel camper and boat.
Had to pull the transmission to replace the flex plate. Transmission was rebuilt according to previous owner an all signs indicate this is correct. I do not know if anything was upgraded to newer E4OD specs.
On to my question... I ordered a tugger kit and metal drain back valve kit. Is there anything else I should look at doing while the transmission is out?
Definitely going to add a drain plug.
