firemedicmonkey
Erie Surf and Ski
So after 6 months sitting in my barn waiting for it's tranny to come back from IL, friday night my IDI finally came back to life, but alas more tranny problems.
So I got tired of waiting for my tranny to come back from the trucks previous owner, so I went out and bought a lower miles E40d on ebay that was out of a 1993 F-350 4x4, suppossedly it has just been serviced and the pump had all new seals put into it.
Friday I finished putting the truck back together including a brand new torque convertor. I filled it up with 17 qts of Tranny Fluid per the book quidelines. I let it set for a while, then I fired it up. The truck fired right up as expected. I let it idle awhile and shifted throught the gears, but the truck didn't move and inch. So i checked the fluid level and it was still overfull. So I pull the codes, and there was nothing special just a vehicle speed sensor and a tranny oil temp code.
I checked the pump output by disconnecting the tranny lines and with the truck idling, it was barely trickling out of the tranny. So I let it set till sunday, then i started it up and now the fluid was shooting out like it should. So i buttoned it up and topped of the fluid. Now the truck would go forward but not in reverse.
So i pushed it out of the barn and took it around the block. From as stop it wants to start in 2nd gear, but once it's going it seems to shift fine, even into overdrive. But still no reverse. I checked all the wiring harness, and the connections, even switched the shift position sensor. Still nothing, I cleared the codes several times, no change at all.
Using a snap on scanner here are the current codes:
Key on Engine off:
23 Fuel Injector Pump Lever out of range
67 Manual lever position out of range - A/C on
Engine Running Codes:
11-No Codes present
Continous codes:
29-open vehicle speed sensor circuit
62-Convertor clutch error
No change in symptoms, still no reverse and it starts in second gear.
Any ideas?
Please help
Key on Engine off:
11-No Codes present
Continous codes:
Any ideas?
Please help
